change VI properties for all VIs in a library simultaneously
I want to change the VI properties for all of the VIs in my library (specifically the Execution properties). Is there any quick way to do this so I can avoid opening up each VI individually?
(3,004 Views)
Accepted by topic author niamh
You can do this through scripting.  Open a reference to the VI edit the VI then save it.  Here is an example that can do this for editing the documentation of a set of VIs.
https://decibel.ni.com/content/docs/DOC-17043
(3,002 Views)
I was hoping for a ready-made menu function but this will do the trick. Thanks!
(2,993 Views)
