 JonathanWinterf
			JonathanWinterf04-20-2010 03:29 AM
I'm writing an XControl containing several booleans, with a numert output based on which button is True, but I cannot change the direction of the Buttons when the direction of the XControl is changed in the VI using it:
In the owning VI, in Edit mode, I change the direction of the XControl via the drop-down menu.
In the XControl, the Direction Change event is triggerd, with {Indicator=True/False; RunMode=False}
I then set the Indicator property of the VIs in the XControl, but recieve an error (see below)
I also noticed this bug: wiring the error to an Error indicator on the XControl Facade yields:
Code: 1073
Source: Property Node (arg 1) in ControlSystem.lvlib:Filtermodes.xctl:FilterModes Facade.vi:31->ControlSystem.lvlib:Filtermodes.xctl:FilterModes Facade.vi.ProxyCaller
<APPEND>
Property Name: <b>Indicator</b>
Whereas a probe shows:
Error 1073 occurred at Property Node (arg 1) in ControlSystem.lvlib:Filtermodes.xctl:FilterModes Facade.vi:31->ControlSystem.lvlib:Filtermodes.xctl:FilterModes Facade.vi.ProxyCaller
Possible reason(s):
LabVIEW: This property is writable only when the VI is in edit mode, or this method is available only when the VI is in edit mode.
Property Name: Indicator
Also, one cannot call 'Explain error/warning' on Error indicators in XControls form the using VIs
How can I change the direction of the buttons in my XControl to match the direction of the XControl?
TIA,
Jonathan
 Intaris
			Intaris
			04-20-2010 04:17 AM
You don't change the direction, you have controls for both directions and hide the ones which aren't being used.
You can't change an indicator to control at run-time.
Shane.
04-20-2010 10:57 PM
@Shane:
I understand that I cannot change at runtime, but this is in Edit Mode of the owning VI (confirmed by RunMode=False in ContainerState).
Or does this not matter, is the XControl always in Run Mode??
Since I can change the direction of myself (http://forums.ni.com/ni/board/message?board.id=170&message.id=429786&query.id=1338874#M429786) I think I should be able to change the direction of children VIs, no?
Seems annoying to have to duplicate every single control even for Edit-mode changes.
Am I missing something?
Jonathan
 Intaris
			Intaris
			04-21-2010 01:49 AM
You want to set the direction of other XControls contained within your XControl? Is this right?
This is an interesting approach. Until now, I have always worked with duplicates of any type of control within my XControls as I have mentioned earlier. Maybe you could make a suggestion on the "Idea Exchange" for this. It is an interesting approach for XControls at least.
Regards
Shane.
 Intaris
			Intaris
			04-21-2010 01:50 AM
Of course something I forgot is:
An XControl dropped on a front panel (whether the FP is in an XControl or not) is ALWAYS in run-mode. It is essentially a parallel process to the VI in which it is contained.
I think this is the problem when you are trying to set the direction in your code.
Shane.
04-21-2010 02:46 AM
So even if the VI is not running, all the XControls on it's FP are running?
This 'code' is the direction change handler in the XControl Facade, if the above is true, then I'm out of luck I guess
Not exactly, I want to set the direction of normal control (Customized, but not an XControl), contained in the FP of my XControl, although it seems like that won't change much
Based on the comments LabView adds to XControls, it seems that the Facade is not running in between processing events, so maybe one could change the direction of the controls after the event handling is done (Some kind of callback)?
My current work-around is to disable my controls in indicator mode, since disabled Modern OKButton controls look identical to their indicator
Jonathan
 Intaris
			Intaris
			04-21-2010 04:06 AM
Correct.
Shane
