change a LabVIEW array outside LabVIEW and keep updated in LabVIEW
hi,
I am Interfacing a FrameGrabber with LabVIEW using a frame grabber
SDK(dll).
The memory managment of this FG allow you to allocate your own Array
and to give a pointer to this Array to the memory manager.
Then when you acquire with the frame grabber, the acquired image will
be directly accessible in your array.
1.I give to the FG memory manager a pointer to the Labview array
through a SDK Dll function.
2. I run the acquisition
3. I display the array
My problem is that the Array is allways displayed with it initial
value. I'am sure that the Array is changed outside LabVIEW.
maybe labVIEW don't reload the value because the Array i
s changed
directly in memory by the SDK.
Is there a way to force LabVIEW to relod the "true" value from memory
thanks in advance!
Sebastien
(2,717 Views)
> maybe labVIEW don't reload the value because the Array is changed
Not really. LabVIEW is dataflow. You will have to actu
ally call the
frame grabber with the pointer repetitively and pass it again and again
to the Control in which you display the image. Look at how the NI-IMAQ
VIs do it. They also use this approach.
Anything else would require access to LabVIEW internas we normal users
don't have and would break with every new LabVIEW version.
The operation you want to do has many problems too, besides of not
fitting well in most high level programming environments. If you write
your application in C you could deal with these issues through video
overlay buffers but Visual Basic, LabVIEW and many others won't work so
simply.
Also you would get unavoidable artefacts of the device driver updating
parts of the image while LabVIEW accesses it to blast to the screen.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(2,717 Views)
