change array index value
Good Morning
Is it possible to change an array index value to begin the count from 1 rather than 0. Within the program I am writing at the moment, I would like it as a permanent feature.
I have made some attempts with property nodes, but without success.
Why do I want to do this you may ask.
So that a lay person can change the row in the array using plain old counting style...1,2,3,4 etc.
Thanks in advance
Ray
Message 1 of 11
(5,849 Views)
No, the underlying primitives for array indexing are always zero-indexed, you cannot change these primitives to use another indexing system. Keep in mind, you can always use the Increment and Decrement primitives to act as transfer functions between your User Interface (UI) and underlying implementation.
Message 2 of 11
(5,848 Views)
You can't.
You shouldn't:
here's a broad discussion on Stackoverflow, which points to this paper that has some nice insights.
A lot of calculations are based on the zero-based indexing.
You could easily replace the current index by your own numbering.
Ton
My LabVIEW Ideas
Message 3 of 11
(5,825 Views)
Your question caused me to experience a flashback to when I used Visual Basic.
Jim
Message 4 of 11
(5,814 Views)
Yes....the range of the array index can be 0 to 10 or 1 to 10...using DIM statement
Message 5 of 11
(5,807 Views)
The index that the operator uses can start at 1 and you can do "minus 1" to start the index at 0 within your code.
Message 6 of 11
(5,799 Views)
I believe MATLAB is also 1 based. Not sure if there is an option to set it to 0 based or not. At least VB has that
Message 7 of 11
(5,791 Views)
In PL/M, an array can have any number as it's index base.
Message 8 of 11
(5,780 Views)
So, why not with Labview? I guess it's never been considered before
Message 9 of 11
(5,744 Views)
Considered and discarded as an idea that has no merit.Smiley Wink
Since you can easily create a front panel control that starts at whatever number you want and you can easily add/subtract from that to index the array, what else do you need?
Message 10 of 11
(5,741 Views)
