The two button dialog is boring. I need to change the font (larger), the background color, the button color, and hilite the important part of the message. Ex: is this color RED ? I'd like to see RED is red.
I think it will be better if you create your own dialog window. Create a vi with all the features you want the dialog window to perform. Edit the connectors of the vi so they return what you want to retrieve (Right-click the upper right icon in the fron panel of the vi and select "Show Connectors"). Then, edit the configuration of your vi so it behave like a dialog box (Right-click the upper right icon again and select "VI Setup..."). Finally, add your vi to your main application vi.
