change column width for print table to report
Hi, want to make the first column in my table to be printed to report wider than the rest, for it contains the part numbers of about 16 chars and the other columns are the data of 4 each. Don't want to make all equally wide for I want to fit as many column as possible over the page. How can I do this?? Thanks for any help. Is there maybe another way to print in a table format?? Madri
(2,865 Views)
Hi Madri,
Assuming you are using the Standard Report type with the Report Generation VIs, you can check out this KnowledgeBase entry that discusses how to customize the VI to generate a report with different column widths:
http://digital.ni.com/public.nsf/websearch/7AEC2CC2618D47DF86256D280058BDA5
Hope this helps,
-D
(2,861 Views)
Darren, thank you so much!
(2,853 Views)
