change front panel background
So you should just be able to go back into the pane properties window and be able to change it back. Are you saying that even after the selection it reverts to its previous format? Also have you tried changing the background of a blank VI and then setting it back to default to see if it is just your Vi or your software?
Here are some references to working with tab controls and changing the front panel which may help:
http://zone.ni.com/reference/en-XX/help/371361K-01/lvconcepts/configuring_the_front_panel/
http://zone.ni.com/reference/en-XX/help/370051Y-01/cvi/uiref/cvitab_control_overview/
http://digital.ni.com/public.nsf/allkb/BD018708882F5C4286256F8C0076B0FB?OpenDocument
Aaron L.
Message 11 of 15
(1,043 Views)
I think it is my software. I was able to do it before but now it doesn't let me. Do I have to get a new software to replace it?
Message 12 of 15
(1,033 Views)
Just try to reinstall/repair.
Exactly how is it not working?  Is the right click menu not coming up?  Is it missing Properties on it?  Do you get the background dialog?  Can you pick a background?  Does it not stick when you say OK?
Message 13 of 15
(1,030 Views)
It doesn't stick after I press ok.
Message 14 of 15
(1,023 Views)
I would also try to reinstall and repair.
Aaron L.
Message 15 of 15
(1,015 Views)
