change japanese to english
Does any one know that there is facilities in labview 8.2 (japanese) to convert it to english?
thank you for your help in advance
heidari
(2,764 Views)
What do you mean by "convert"?
If you want the development environment to be in English, you probably need to insert the LabVIEW CD and go though the installation process or try (in Windows) going to Control Panel>>Add/Remove Programs>>National Instruments Software and select Modify for 8.2.
If you want your VIs to have both a Japanese and English interface, you should look up "localization".
___________________
Try to take over the world!
(2,761 Views)
