change labels language
Hi
      I've installed LabVIEW 2009 Evaluation software(English) on my system. I want the names of labels of controls/indicators/constants in Deutch language. Is there any way doing it ?
Thanks in advance.
kiranmayi
(3,652 Views)
(3,643 Views)
Not like this, Muks. I want to change the Language of each and every label. Is there any option available in VI properties ?
kiranmayi
(3,633 Views)
Manully add the new font and labview will automatically update the fonts that has been registered in windows. I have added new fonts this way.
(3,627 Views)
The way that I have done this in the past is to save a list of words and their translations as a 2D array in a text file. You can then use the control references to set the control caption property to the apprrpriate language. You will need to create a way of searching your native language column in the array and returning the translated word.
This method allows you to add languages at a later date without  changing your exe
David
www.controlsoftwaresolutions.com
(3,590 Views)
