change of input parameters at each for-loop iteration
Dear all,
It would be very nice if somebody could give me some help and suggestions for the following:
Situation:
As an example shown in the attached program “changed input at for_loop.vi” I have a signal with e.g. three peaks. I am splitting the raw waveform signal in its single peak arrays, using the “Array Subset.vi” three times. For each single peak I am using a pair of input parameters (which are manually set), namely a “peak start index” value and a “peak length” value. In parallel to the peak splitting, a threshold position for each single peak is determined by using the “Threshold 1D Array.vi” function.
Problem:
This procedure works fine, but is not very flexible because for each additional peak I have to add an additional “Array Subset.vi” and “Threshold 1D Array.vi” function.
1. Because I will have more than 3 peaks, I would like to place one “Array Subset.vi” and “Threshold 1D Array.vi” function in a for-loop, so for each peak the loop iterates once and produces as output the single peak array and its threshold value.
For this situation, the input parameters at each for-loop iteration have to change to the manually set values for each of the peaks. How can I do this?
2. Additionally, I would like to “switch off” peaks using a Boolean true/false. For example I am switching off peak 2. That would mean that peak 1 in the first iteration of the loop would be processed. Peak three would be processed in the 2nd iteration and not in the 3rd iteration. How can I do this?
It would be very nice if somebody could help me with this.
Kind regards,
Beam
(3,185 Views)
You can do that by having an array with the settings and conect that to a for loop, it will auto index that array and run as many times as you have settings
I changed your vi, take a loop at the attachment.
Hope this helps,
Paulo
(3,177 Views)
Hi, I forgot the on off...
(3,170 Views)
