09-13-2013 04:47 AM
I have an Device for interferometric Displacement Measurements that gives out an digital A quad B Signal plus the clock signal (runs at 10MHz).
I wanted to use the DAQ Assistent to calculate the Displacement. The Problem is, if I select the "linear Position" Option it wants me to use the Inputs PFI8 and PFI10 for A and B.
Unfortunately we use a BNC2110 Box which only connects PFI0 - PFI9. Leading to my qestion: Is there a way to change that Pin-Configuration?
If not, are there complete vi´s available for downliad where I can select the Inputs for A,B and clk and that at least gives me the A and B Signal in Labview?
Setup-wise we are using a 6259 M-Series PCI DAQ-Card which should be able to handle 10MHz.
I would be really happy if anyone can help me with that!
Cheers,
Daniel
09-16-2013 07:18 AM
Hi Daniel!
Unfortunately the DAQmx assistant is limited to a small subset of the DAQmx capabilities. If you want to change the PFI assignment for a counter task you have to use the low level DAQmx functions provided in the Measurment I/O > DAQmx palette. I attached a small example where you can see how PFI for a Counter Linear Position Task are assigned with a DAQmx property node. Hope that helps!
Georg
09-18-2013 02:19 AM
Hi Georg,
thanks, that helped a lot!
The systems actually works right now but not at the needed rate. The PCI Card should be able to handle 10MHz. I´m using the clock signal of my device (10MHz) but the output of the vi is at 100kHz (new datapoint every 10us).
I just created a loop around the dataoutput subvi to make it an array with all the measurement points. Also tried it using the NSample VI instead of the loop and a single value output, but the same result.
What am I missing? Am I doing something wrong?
Cheers,
Daniel
