change properties of controls in an array of clusters
One last trick... Attached is an example that uses the ideas I have presented to no only change the visual properties of each display element independently, but it now looks like each element actually contains different types of data...
Unzip the archive into a directory by itself and run the VI "~Interface Test.vi"
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 12
(720 Views)
Thanks Mike,
this is an involved solution you got there. i am now sort of doing the same. cant use your one, because i have to dig too deep into every cluster to change what i want. but i take the same architecture.
will update you on developpements.Smiley Happy
... And here's where I keep assorted lengths of wires...
Message 12 of 12
(706 Views)
