change properties of wma file
With LabVIEW, is there a way for me to programmatically change the properties of a wma file?  For example, for a given song name (Song1.wma), I want to be able to change the album title, track number, artist name, etc.
(5,638 Views)
You can use the Windows Media Player ActiveX interface...
(5,628 Views)
Are you talking about communicating with Window Media Player via ActiveX or is this an interface that is within Windows Media Player?
(5,624 Views)
It's the same thing, actually. Windows Media Player has an ActiveX interface so you can use it from LabVIEW. For instance, the "SetItemInfo" method will allow you to change certain attributes.
(5,618 Views)
Discussion moved to here.
(5,595 Views)
