05-14-2007 06:48 PM
05-14-2007 07:04 PM
Yes you can edit the size. It isn't user friendly. You have to resize each button individually. Select one of the radio buttons in the box. From the Edit menu, select Customize Control. Once the control front panel opens, click on the little wrench symbol and it will turn into a pair of tweezers symbol. Now you can edit any section of the control. Simply resize the button. Then click on the tweezers to change it back to a wrench. From the Edit menu, select Apply Changes. Your new button should appear on the front panel. Then you have to do the same for the other button.
I wish NI would make this resizable like LEDs and other buttons.
05-14-2007 07:07 PM
I tried the tweezers in the customize tool, and that didn't work.
Actually, I just tried replacing the radio buttons in the cluster with LEDs, and the resizing works perfectly.
I can also set the attributes to be different colors.
Perhaps this is an undocumented feature and not a bug that was eliminated in 8.0
05-14-2007 07:18 PM
