change returned value of enum
I have an enum which i store a list of strings and then when the user changes the enum to a different item it returns a value but can the returned value be changed?
For example
Item name 	value
Item 0            0
item 1            1
item 2	          2
item 3	          3
 but what i would really like is this;
Item name	   value
Item 0	            0
item 1	            7
item 2	            8
item 3	           12
 Is there anyway of doing this without adding a number on after the value is returned?
Many thanks for your help.
James
(5,072 Views)
Hi James,
use a ring instead...
Enums are just "enumerated", they always count their items!
(5,071 Views)
fantastic, i`ve been looking for this all day.
Thanks for your help.
(5,066 Views)
just found the strings and values property for the enum which does exactly what i need.
(5,058 Views)
Yes you can read those property but you will not beable to write. Enum won't allow you to do that but in ring you can do both.
(5,056 Views)
yep just found that out so the text ring will do exactly what i need. I have always wondered what the difference between them was.
thanks for you help.
(5,052 Views)
May be this would help you to understand the difference.
(5,046 Views)
