change tank amplitudes when certain conditions are satisfied
I have three conditional variabls and I want to change the tank amplitude on the basis of these variables.
Let a,b and c are three conditional variables
If a>b; tank amplitude is 2
If a=b; tank amplitude is 4
If a<b; tank amplitude is 8
Best Regards
Muhammad Abul Hasan
Message 1 of 8
(2,944 Views)
Where are you stuck? Attach what you have written so far. If you are using integers, its a trivial problem.
Message 2 of 8
(2,941 Views)
If I have two variables only a and b than I can use event structure but for three conditions I dont know what should I use.
Message 3 of 8
(2,930 Views)
You can wire an integer directly to a case statement.
Message 4 of 8
(2,921 Views)
Can you show a simple block diagram>
Message 5 of 8
(2,914 Views)
Take the 'A' variable and wire it directly to the selector of a case statement. Very, very simple action. Then, look up the help for the case statement to see how you can set the values for each case. Hint: the values can be a range.
Message 6 of 8
(2,908 Views)
Here is what I would do
Tim
GHSP
Message 7 of 8
(2,898 Views)
Well, I'm not going to post my solution since I think this is homework. I've mentioned integers to the op a couple of time but got no response. Integers would require nothing but the case statement. In this case, the equal comparison with floats is going to be problematic.
Message 8 of 8
(2,896 Views)
