Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
change the pages of a TAB control programmatically
Frank S. P.
Member
04-19-2001
05:10 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
How can I change the pages of a TAB control programmatically, but not by pushing the tabs in Front Panel when program runs?
0
Kudos
Message
1
of 3
(5,652 Views)
Reply
Re: change the pages of a TAB control programmatically
Brian_Vibert
Active Participant
04-19-2001
06:17 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Create a property node for the tab control (right-click>Create>Property Node) and select the value property. Change it to write mode and wire the number of the page you want to change to (0=page 1, 1=page 2, etc..)
Brian
2
Kudos
Message
2
of 3
(5,652 Views)
Reply
mfitzsimons
Active Participant
12-19-2003
02:04 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
100% correct, Thanks
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
0
Kudos
Message
3
of 3
(5,652 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
