change the way physical channels are selected
Aug 1
Group:
I am using NI-9213 to collect thermocouple data and Labview 2014.  On the front panel the user uses a drop down to select the number of thermocouples to include in the test.  For example, if the user wanted to use the first 5 thermocouples, the user would select "Dev1/ai0:4"
Is there a way to change this to "thermocouple 1 - 5"
thanks for your help
Tom
(3,318 Views)
Not exactly. You could try defining virtual channel names, or create a pull down menu of your own that says whatever you want.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,284 Views)
Instead of making the user work in NI terminology, you do it in the background.  Allow the user to select a starting and stopping thermocouple or have a listbox to allow them to select what they want to measure and you build the string to pass into DAQ.
(3,188 Views)
