changing active excel sheet
Hi
how can I change the active sheet in excel with activeX-commands? I haven't found any example yet? I also tried to change the index in "open specific worksheet.vi".
Message 1 of 9
(6,301 Views)
Find attached an example to select an active sheet.
The VI is in LabVIEW 6.1 and uses some of the VI from LabVIEW's excel example vi's.
Regards
Ray Farmer
Regards
Ray Farmer
Message 2 of 9
(6,298 Views)
Thanks alot. it works wonderfully.
is it also possible to choose the active sheet by its name?
Message 3 of 9
(6,298 Views)
Yes, instead of wiring an integer to the Sheets.Item method, wire a string.
Attached is modified example
Regards
Ray Farmer
Regards
Ray Farmer
Message 4 of 9
(6,298 Views)
Hi
Thanks alot Ray.
it's quite easy this way. do your know a good page where I can downlaod and choose vi's for activeX and excel. por did you made them all by yourself?
regards
Yves Dieplinger
Message 5 of 9
(6,298 Views)
Hi Yves,
No I started from the example VIs found in the LabVIEW\examples\comm\ExcelExamples.llb. Then viewing the available methods and properties and using the help come up with a solution to your question.
There is a Toolset you can purchase from NI, ( http://sine.ni.com/apps/we/nioc.vp?lang=US&pc=mn&cid=5769 ).
Regards
Ray Farmer
Regards
Ray Farmer
Message 6 of 9
(6,298 Views)
hi
do we need to purchase the toolkit in order to transfer the data from labview to excel files?
Message 7 of 9
(6,268 Views)
To have LabVIEW communicate to Excel, you do not need to purchase the Report Generation Toolkit. The above examples you should be able to open in LabVIEW even if the Report Generation Toolkit is not installed. To communicate, you will need to use ActiveX and understand Microsoft's object model. There is a good tutorial discussing how to integrate Excel into NI software:
NIDZ Tutorial: Integrating Microsoft Excel with National Instruments Software
And just in case you're interested in the Report Generation Toolkit:
NIDZ Tutorial: Creating a Report in Microsoft Excel Using the LabVIEW Report Generation Toolkit: Int...
Hope this helps. 🙂
Kileen
Message 8 of 9
(6,256 Views)
Yves
Here is some VI's that will help you out a lot.
Joe.
"NOTHING IS EVER EASY"
Message 9 of 9
(6,253 Views)
