changing bit resolution
Hi all,
Is anyone familiar with changing the bit resolution of a binary file that outputted data from a NI Analog to Digital Converter?  It was originally setting the data on 24 bits, but I want to convert it down to ie 12 or 16 bits..
Would there be a routine for LabView to read back those binary files, somehow make it back into an analog signal, and resample with a lower bit resolution?
Thank you very much. Smiley Indifferent
Message 1 of 15
(5,973 Views)
There is definitely no need to take the detour over analog. You can simply take your 24 bit data and rescale it to the desired final bit resolution. How many of the 24 bits were actually used?
Message 2 of 15
(5,960 Views)
I'm not really sure how much of the 24 bits were used.. That's why I wanted to test out the data with different, lower bit resolutions to see if it was still good.  What are my options to rescale it down to final bit resolution?
Thank you for giving me hope! Smiley Very Happy
Message 3 of 15
(5,947 Views)
Are the binary values integers?  You could use the logical shift function in the Numeric, Numeric Conversion palette to shift your bits so that the least significant bits would fall off and the resulting number would the value rescaled in a fewer number of bits.
Message 4 of 15
(5,931 Views)
They were floating point.  Is there a way to do this so that you know how much bits you are converting it to?
Thanks!!!
Jud~
Message 5 of 15
(5,867 Views)
You can find the max and min value of your data, then scale it accordingly.
I think you have this backwards! 🙂 How many bits you want is your choice, so you have to make that decision.
Message 6 of 15
(5,863 Views)
I think I understand.  Thanks! Smiley Happy
Message 7 of 15
(5,857 Views)
I tried to put that logical shift together, with y=8 and x=data array read from binary file at 24 bits.  The data out of the int 16bits (blue lines) aren't graphing as they previously had..  Does anyone know why?  I changed the digits of precision to be high enough on the graphs already..  Thank you.
Message 8 of 15
(5,833 Views)
I have no idea what you mean by y=8 or logical shift, and your program does not really help much without having any of the datafiles.
For simplicity, could we focus on a single data file, attach the data file and a simplified VI on how you are trying to convert it.
Changing the digits on the graph is a purely cosmetic property and will not change the underlying data or the display.
Message Edited by altenbach on 09-03-2008 02:39 PM
Message 9 of 15
(5,829 Views)
Sorry for being vague, I meant to say the logical shift function, https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/functions/logical-shift.html, and the x and y pertaining to the function.
I reattached a simpler .vi and a bin file.  Hopefully that helps!  Edit:  Attachement here:
The bin file is too big for this forum 😞
Thanks~ Smiley Tongue
Message 10 of 15
(5,823 Views)
