changing data range during runtime
Hi guys!
I want to use a Gauge Indicator and a knob control in my VI. What i want is to change their data ranges during runtime. I should be able to change its max value, min value as well as increment so as to suit my readings. How is that possible. I try doing something with property node but i couldnt do that. Kindly help me.
Shaiq Bashir
(3,421 Views)
It's done with the property called Data Entry Limits. What property did you use? If it's this property, post your code so someone can see what is wrong with it.
(3,411 Views)
What exactly isn't working? Were you not able to find the properties, or did the control not accept the values, or what? Are you also changing the scale info to reflect the change in data ranges?
(3,409 Views)
See attached VI (Version 8.5)
hope this helps,
Norbert
[EDIT]:Missed to attach VI ..... 😞
Message Edited by Norbert B on 11-16-2007 09:09 AM
Norbert
Expert: Geometry
(3,408 Views)
Use the Scale.Range Property node, and it will change all the funtions for you.
Kenny
(3,404 Views)
