changing duty cycle for PXI 5422
Hi
I am using the PXI 5422 as a standard function Generator to generate a square wave. However I want to change its duty cycle.
I know it is possible to do that because the niFGEN (.exe) has the provision for changing the duty cycle of a square wave.
However I could not find a niFGEN function which would allow me to do that.
Any response will be appreciated.
Nishad
(2,850 Views)
Hi Nishad -
There is a property called Duty Cycle High that you can set on-the-fly.  It only works for square waves.
Message Edited by David S. on 07-27-2007 10:17 AM
David Staab, CLA
Staff Systems Engineer
(2,846 Views)
Got it. Thanks
(2,836 Views)
