changing namelabel text on dual Y-axis chart
Hi Guys,
I need to chart temperature (degC or fahrenheit) and loadcell (newton or kilonewton) on one chart. I plan to use multi signal graph with dual Y-axis. I use option button to select and block diagram to change the Y-Scale name label text. Problem is the changes only change the right side Y-scale. How do I change the left side Y-scale?
(403 Views)
Hi wan,
Do you set the active Y scale before setting its label text?
(398 Views)
Accepted by topic author indcon_wan
Thank Gerd for the solution. It works.👍
(384 Views)
