changing selection property
hi all ..
an other question for you...
i like to customise the selection of multiple element in a list box. In fact i like to allow multiple selection with "ctrl" and not with "shift" as it is defined. It's just to keep the same rules as in windows explorer....
thanks a lot !!
(3,194 Views)
LabVIEW 7's event structure has additional filter nodes that allow for the modification of the event when the usre mouses down. The attached VI changes the keyboard modifers so that when you press control shift is sent to LabVIEW.
(3,194 Views)
Hi, your answer is not helping me because i'm using labview 6.1 and not 7.0... So the question is the same but with labview 6.1... thanks any more
(3,194 Views)
