channel config with daqmx
how can I set the config for the first, the second and the fourth channel on the daqmx-config?
I tried with dev1/ai0:1,3 but this is not working.
thanks for any help
yves
(2,457 Views)
Hello Yves,
The syntax for a channel list is outlined in the DAQmx help file under "channels, physical syntax" in the index, or by searching the help for "Physical Channel Syntax".
Try following for your configuration:
Dev0/ai0:1, Dev0/ai3
Regards
Message Edited by Indiana on 04-21-2005 09:14 AM
(2,443 Views)
