characters y and b appear when reading a text file
The vi shown in the picture opens a text file from hard drive with "Open/Create/Replace File" and with "Read from Spreadsheet File".
Then the vi displays the text in the respective indicators.
In both indicators, there is a y and b that appear as the very first first characters.
It's not exactly a y and b. The y has two dots over it and the stem of the b hangs low, a non-English script.
In Word and Notepad these charcters don't show up. The first character is a zero as I originally wrote.
The text file was originally created in Excel and then saved as unicode text.
From whence do these funky letters come? and how do I get them to leave?
Also, it looks like the text in both indicators is adding a blank line after each line. That doesn't show up Notepad or Word either.
(3,410 Views)
Accepted by topic author Carmen92126
There's your problem: unicode.  You might want to check out this quick thread: Config file "byte order mark"
Yes, by saving as Unicode, you have a couple of extra bytes that most text editor know to ignore.  But LabVIEW just gives you the raw data.
(3,396 Views)
Saving the original as "Text (Tab Delimited)" solved the problem.
Thank you.
(3,367 Views)
