charts
Is it possible to create a bar chart instead of a line chart. What function should i be looking at if it is possible.
thanks
mike
(3,707 Views)
Hi Mike
On the plot legend, right click the plot you want to change and select "Common Plots".
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,693 Views)
Hi Becktho
Is this the same for labview 6.1. If i right click on my graph i do not see common plots.
thanks
mike
Message Edited by newyork on 03-01-2006 04:38 AM
(3,694 Views)
You don't have to click on the graph, but on the graph in the plot legend:
Message Edited by becktho on 03-01-2006 11:41 AM
Using LV8.0
(3,689 Views)
thanks you Becktho
(3,681 Views)
