chasis communicator not present
I am trying to set up my test board on a Windows XP computer using LabView 7.1. I believe I have installed all the drivers and software that is needed. It seems as though my system is being recognized by the computer, but I am unable to communicate with my test board. I have attached the error I am receiveing when I try and test my set up using the Measurement and Automation Explorer. Any help with how to get around this issue would be great. Thanks.
-Kurt
(2,908 Views)
The attached is the error I get when I try to reset the module.
(2,906 Views)
Which versions of DAQmx did you install?
Is the device loader started?  Control Panel»Administrative Tools»Services»NI Device Loader
Take a look at this KnowledgeBase article and let us know if that helps.
Jacob R. | Applications Engineer | National Instruments
(2,893 Views)
Jacob,
Thanks for the reply. I believe I installed DAQmx Version 6.93. Is there a way to confirm which Version I have?
My device loader has not started. I have attached the error I get when I try to start the loader, as well as a view of my services page. It seems to me like I am missing something that is keeping me from communicating with my devices. Any help would be great. I am beginning to get lost with all of this.
Thanks for the article as well. I will see what tips I can get from it.
(2,873 Views)
