check if NI-DAQmx installed
Hi everyone,
I'm brand new to LabView working on it in uni and dont think I have all components installed i need ie NI-DAQmx , before I hand my computer over to IT and lose it for 3 days, can I just check that if I am unable to find DAQ assistant on Functions express input, and functions search that I am missing something? I have version 10.0.1.    If I am missing something do you know what components I need to have installed?  As i dont have administrator rights to do it myself, and IT will not know.
Many thanks,
Thom
(5,183 Views)
You would use Measurement and Automation explorer to borowse the NI components installed (MAX>>Software.)
(5,182 Views)
So if NI-DAQ is no where in that tree, I need it?
(5,177 Views)
Accepted by topic author ThomB
If DAQmx is not in MAX, then you probably need to install it. For LabVIEW 2010, you can use the newest version of the driver, DAQmx 9.4. I will warn you that the download is rather large (~1.5 GB), but should get you the DAQ Assistant and other VIs.
Tim W.
Applications Engineering
http://www.ni.com/support
(5,171 Views)
Thankyou both.
(5,162 Views)
