check if VI is a control (.ctl)
Given an array of VI references, is there a method to determine which VIs are actually controls (.ctl files)?  (Other than getting the path and checking that the file extension is .ctl.  I was hoping for a more direct way.  Smiley Happy)
Joel
(2,914 Views)
Accepted by topic author Snood1
If you already have a VI reference, you can read the "VI Type" property and see if it is equal to "Control VI".
-D
(2,909 Views)
There it is!  Thanks!  Smiley Very Happy
(2,905 Views)
