check if a reference on a control is valid
I used to use reference on control when calling a sub Vi.
I would like to check in the subVi if this control is really connected for example, in other word if it is reallay a reference to a control (or indicator).
How can I do it ?
thank.
(9,505 Views)
If the reference is not valid you will get an error when calling a property node (or invoke), at the error cluster output.
You should always wire it, if you are not sure about your references
Message Edited by Pnt on 07-25-2008 03:28 PM
(9,499 Views)
Not a Number/Path/Refnum? is your friend. Functions palette >> Programming >> Comparison
(9,498 Views)
30 seconds ago there were no replies. I should aviod the "low hanging fruit" Smiley Wink
Ben
Message Edited by Ben on 07-25-2008 07:30 AM
(9,498 Views)
Ben
Well wouldn't it be nice to link to the online help of the function?
Or perhaps a picture from the online help:
Ton
My LabVIEW Ideas
(9,485 Views)
LOL, I was lazy to start LabVIEW to get to that help page so I decided to google it and this thread was the first hit. So you were right it was nice. 🙂
(4,665 Views)
