05-24-2007 02:48 PM
05-24-2007
02:54 PM
- last edited on
09-19-2026
04:52 PM
by
Content Cleaner
You can find your anser here: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIEJCA4&l=en-US
05-24-2007 03:04 PM
05-24-2007 03:10 PM
Thanks for the responds, but the application I'm trying to check is not vi. It's actually a database file.
03:13 PM
- last edited on
09-24-2026
02:15 PM
by
Content Cleaner
OK, but is this database file opened from within an application, and is that application running? Then the tasklist command will tell you that.
If you want to see if a specific window is open you can call the Windows API (I'm still assuming you're in Windows) to try to get a handle to the window name. If you get a handle, the window is open. You can use the Windows Utilities for this.
05-24-2007 03:28 PM - edited 05-24-2007 03:28 PM
Thank you very much. This resolves my problem! Thanks again.
Message Edited by tgif on 05-24-2007 03:29 PM
