chinese file name
Hi guys,
I tried to open a vi with chinese file, it does not open. when i try to open by select open vi and choose that vi, it seems LabView does not recgonize the chinese file name. If i change to english name, it has no problem. It has vi with chinese. i could not change all  into english file.
Best Regards
Message 1 of 9
(4,208 Views)
I forgot to mention, I am using LabView 2011 english edition and windows 7 english edition
Message 2 of 9
(4,203 Views)
English LabVIEW is not going to understand Chinese filenames, just like English speaking people are going to understand Chinese characters.
If you are going to program in Chinese, you are going to need to stick with Chinese LabVIEW.  Otherwise, you are going to have to translate your files to English or another language that uses normal characters.
Message 3 of 9
(4,181 Views)
I fixed it, the Windows 7 has the language locale. It needs to be set on Chinese PRC locale.
Message 4 of 9
(4,150 Views)
how u fix it?
Message 5 of 9
(3,984 Views)
Just read the post above yours.  Sheesh.
Bill
CLD
(Mid-Level minion.)
Message 6 of 9
(3,968 Views)
As said above I opened my chinese .vi renaming the file in english, but still the contents are in chinese, since there isnt chinese charaters in labview 2015 that I'm using chinese charaters are displayed as symbols. Could anyone please suggest me a solution for this, i wan to translate that chinese into english.
Message 7 of 9
(3,839 Views)
Did you read any of the suggestions above?  What did you do so far?
Bill
CLD
(Mid-Level minion.)
Message 8 of 9
(3,832 Views)
哥们,你为啥不用中文版的LabVIEW呢,不是可以解决一切问题了吗?
还有,你的英文和我的一样烂,哈哈!!
Once for all!
Message 9 of 9
(3,803 Views)
