chipkit led5 doesn't set as output ?
Hello, guys i started to learning about chipkit with labview interface and the blink with led 4 works well, but when, i changed the pin to 43 or led 5 it doesn't work what i have to do?
(2,756 Views)
It's possible you have blow the port.  See if you can read from it when configured as an input.  Be sure not to supply more than 3.3 volts to the input.
Machine Vision, Robotics, Embedded Systems, Surveillance
www.movimed.com - Custom Imaging Solutions
(2,713 Views)
Hello MoviJOHN
I tried to put pin 43 as input, but got no answer you have any example for me to test the operation of the input? And there's another problem that I have tested the example with mpide blink and it worked perfectly. Do you know how I could fix it, if it's some kind of bug? I am using aa version of uc32, is there any incopatibilidade?
Thank you,
Leonardo.
(2,708 Views)
When I go to test pin 43 I get the following response.
(2,704 Views)
