09-27-2006 11:50 PM
Told you so
Pleasing the boss is a super human feat![]()
still benco, did you check out the resolution of your card and its accuracy??
your readings may still be correct and adhering to the accuracy level promised by your DAQ card
09-28-2006 03:25 AM
Thank you maximus
it's very nice
i send you data and a picture
09-28-2006 03:26 AM
09-28-2006 03:26 AM
09-28-2006 03:32 AM
09-28-2006 04:27 AM
Hi benco,
I think you are solving the problem from the wrong end. Of course you can use filtering in LabView to reduce the noise. But this kind of noise shouldn't be there in the first place! When I see this kind of behavior in a system where I'm trying to make a measurement, I usually take a closer look at the signal with an oscilloscope, and then I call in my electronics technician to help me solve it if I can't solve it myself.
Filtering bad signals is better than doing nothing, but getting good signals is much better!
cheers
Martin
09-28-2006 06:03 AM
09-28-2006 08:09 AM
09-28-2006 08:12 AM
09-30-2006 08:47 AM
