hi
iam using  an distance laser sensor  to measure the displacement , over 12mm in 15ms, I want  to use  a  signal conditioner before the DAQ, and I've checked the Portable Modular SCC, there I saw the  NI SCC -AI Serie isolated analog Input ; I know inside it there are  low pass filter, instrumentation amplifier, but  i dont  have detail information about them. My application has to be portable that's why i wanna use the SCC. in the attach file you 'll find a graph of the signal  be to conditioning, later  on using labview I will defferentiate the graph to have the speed
My questions are
Is it there some specific datasheet about the NI SCC-AI Series
are there some other protable conditioner i can use for this application
