choice of the interface module, for step motor
I would to control a step motor through the Labview software (control speed, direction of rotation, number of steps ...) Thus, I would like to know which module interface NI would be the best suited to my engine, for the control and the electric supply.
The engine is a : Superior Electric, type M061; 7V, 7A
Furthermore, I also looking for all documents (examples, tutorials) that can help me to program the VI on Labview : hardware installation, programming on Labview .
Many thanks for your help,
A. Benjamin
(3,127 Views)
Are you looking for the Software interface only? Do you have the drive and controller already?  Are you looking for a PCI solution or a cRio? NI offers different solutions. Check Motion Control from NI. Also here are some links to help you understand the concept. When you decide what approach you want to go, let us know and we can help you get started. Also, many examples will be installed when you install the NI motion drivers.
Fundamentals of Motion Control
Motion Control Resource Kit
Thanks and have a great day.
 Esmail Hamdan | Applications Engineering | National Instruments
(3,090 Views)
I have already the required devices for cRio solution. I have a stepper driver P70530, a module NI 9512 and a controller NI cRIO 9074.
I am looking for an example of Labview code for this kind of set up for one or several axis.
Many Thanks,
A. Benjamin
(2,951 Views)
