choose channel in waveform charts stack plots
my problem is: I measure on DAQ, I want to measure for example six channels, but display in waveform chart with stacked plots only two channel. I want to choose during the measurment which channels to display. For ex. I display at start the first and second channel, than I want to change it to third and fourth one. I can´t find this selection in property node of waverform chart. How can I do this??
(4,127 Views)
Hi oliva,
You can select which waveform to display on the stacked plots by indexing and build your array subset of waveforms before you pass it into a Waveform Chart indicator. I've attached a simple example to illustrate this. You will need LabVIEW 8.0 or greater to open the example.
Stanley Hu
Applications Engineering
http://www.ni.com/support
Message Edited by stanthetiger on 01-18-2008 02:52 PM
(4,101 Views)
