choose defult value from list
Hi
I build vi that read from ini file and put it in drag list ( attach vi)
what I need to know If I can make and defult name that always this name will be sign when start this vi
example
the list include 5 name and I alyaws want that item 3 will be defult alyaws to choose it
can I do that in labview?
just now that I am using labview 2013
when you try to run this vi plesae place ini file that attach in c:\temp
(2,431 Views)
Hi Elyan,
you can set a default value for each control/indicator in its right click (context) menu.
Or you could use a local variable of a control to set a certain value…
(2,418 Views)
