choosing only an output
Hello.... my objective is choosing only an output which will enter in a case structure....
Look at the image: I've six boolean output... one that is [0 or 1], another [0 or 2],.......another [0 or 6].
Only one input is different than zero... so that i would like to choose only that output that's different than zero... what shall i do?
Excuse for my grammar, but i'm italian.
(3,114 Views)
There are a number of ways to do this, several of which are suggested in this thread.  The actual question in that thread was different but the approach to solving the problem is the same.
(3,098 Views)
Yes, depending on what you want to do and the number you are comparing (is it in fact a DBL?) there could be different ways of doing this. Here are a couple ideas.
(3,095 Views)
Hi SenedLoos,
you know there is a InRange function on the comparison palette?
For the rest you should read Darrens nuggets they explain all kinds of case structures... (starting here with message 109)
(3,092 Views)
