cin: object code path&name
labview 5.1
Which way one can know the name & path of the objectcode file (lsb) of
the cin node when working with diagrams?
Alexandre
(2,946 Views)
Hi Alexandre-
I have not figured a way to programmatically load the name of a lsb file. Creating a string constant with the name of the lsb file would not be a bad solution (although not super-elegant either) because you can not dyanmically change the lsb file the CIN is linked with - make sense?
The CIN does not allow you to create create a property node - that is only way I think you could access it...
ben schulte
national instruments
(2,946 Views)
