cin with C++ builder
I want to use a CIN witch is program with Borland C++ builder5. But when I compile, I have errors:Links erreur ...OMF OX... for cin.obj, labview.lib etc...
(3,403 Views)
AFAIK you can't use BCB to create CIN's, but have to use M$ VC 6.
Borland uses a different library (and obj) format , so that explains the
linker error.
You can use DLL's create with BCB though
regards,
Cees
> labview.lib etc...
(3,403 Views)
I try with DLL, but when I compile the DLL with BCB, I have an error:[Lieur Erreur] 'C:\PROGRAM FILES\NATIONAL INSTRUMENTS\LABVIEW 6\CINTOOLS\LABVIEW.LIB' contains invalid OMF record, type 0x21 (possibly COFF)
I try to convert labview.lib, COFF to OMF with coff2omf.exe, but I have a file of 1koctets; so the compile is an error
(3,403 Views)
HI Jules51,
At install time (of LabVIEW) you are given the option to install the support libraries for Borland.
You may have to do a custom install to get at this option.
Ben
(3,403 Views)
I re-install Labview with custom, but I don't find the support libraries for Borland
(3,403 Views)
