circutor usb rs485
Hi
How to connect circutor usb to rs485 dasylab 11.0 ? what is the maximum number of devices on this converter?
Thanks for your time.
(4,648 Views)
@JackPM wrote:
Hi
DasyLab discussion at http://forums.ni.com/t5/DASYLab/bd-p/50
Circutor is not a NI product. Go ask them.
(4,641 Views)
This is the LabVIEW board. You should post DASYLab questions on the DASYLab board.
This device is simply a converter. The number of devices for RS485 on one port is defined by the RS485 standard. It looks like 32 is the maximum per port.
DASYLab will communicate with the device using a driver (e.g. ADAM, DGH, NuDAM) or via the general RS232 port.
You have not mentioned the type of device that you plan to connect.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(4,639 Views)
Please click on options and ask the moderator to move your question to the dasylab board. You posted to the LabVIEW board.
(4,637 Views)
im getting temperature readings from pid controllers.
(4,627 Views)
What you are reading is generally irrelevant at this point. You've been told to post to the appropriate board but have not done that.
(4,596 Views)
