class & object support in labview
    how can we create classes in labview??
(3,499 Views)
Hi Sithu,
if you using labview 8.x, open the project explorer and right click on "my pc" and select "new" -> "class". If you need more, then please describe more about your intentions.
Hope it helps.
Mike
(3,496 Views)
Hi Mike,
              Can you provide me any simple VI implementing the class concept ?
(3,492 Views)
Hi Sithu,
i´m not sure what you need. Did you try it?
Mike
(3,488 Views)
This is what mike told. Try.
Message Edited by mathan on 06-06-2008 01:28 AM
(3,483 Views)
From your question, I assume you're coming from an OO background. Before you start using the built-in LabVIEW OOP, you should do some reading, because it's not entirely the same as in other languages. Here and here are a couple of links you can start with. The second link includes some details about the differences.
Also, you can find LVOOP example in the example finder (Help>>Find Examples).
This is a good method in general - if you want to learn about something, search for tutorials and examples.
___________________
Try to take over the world!
(3,469 Views)
Thanks....
(3,465 Views)
