class not registered error
Hello ,
I am getting an error for Class not registered. I registered this dll on the machine again. However now i get an error msg. saying unknown system error with some weired numbers like -2146828235. I looked at some of the previous threads. I did clean up the duplicate copies. but i dont know why it keeps giving me this error.
Also to be noted a thing is that I did not get this  error previously, whenever I did get one, i tried to select the class again from the LV and it worked.
Any suggestions on this one will be much appreciated.
(3,331 Views)
It sounds to me after you registered, it wasn't saved.  The error could comes from the DLL.
------- LabVIEW 2009, So Easy, Even a Therapist Can Do It -------
(3,326 Views)
Thanks. I figured it out tht the dll was not saved properly to the path it accessed from.
Thanks again for the help.
(3,319 Views)
