clear charts
I know this one should be really easy.  I have 4 charts under a tab, and I want to clear all charts.  My problem is that I have a case structure and inside it, another case structure with a clear chart linked to it.  I am linking an array of zeros to the chart history within the case structures, which has worked before, but I can't remember how I linked the generic history property to the specific graph.  This screen shot, as you can see, I have done it in the upper case structure, but the bottom one, for some reason I am confused.  Please NI gurus help a lonely novice.
http://i29.photobucket.com/albums/c300/Natron3030/screen.jpg
(3,264 Views)
Right click on property node... select Link to ..... Pane ....[your control]
(3,263 Views)
Beautiful!  I new it was hiding somewhere...thanks Pnt 🙂
(3,258 Views)
controlled by gammalight!
(3,240 Views)
