clear data on displays and graph automatically
i am trying to run my vi program each time I running the program it save last data in my displays and graph i need to automatic reinitialize the displayed data and graph to the defaukt each time i start run the program and clear the data and graph automatically when i running the program
(2,720 Views)
Hi Alaa,
usually you need to save data to a file on disk whenever you need to retain data between runs of your program...
(2,712 Views)
You can create Property Node>>value for the graph and write empty array whenever necessary.
uday
(2,701 Views)
Hi Alaa,
opne the example finder and look for "graphs" and "charts". There's an example explaining how to use (and clear) both...
(2,698 Views)
