clear event structure queue
My current setup would require that I cancel all events after 1 event is fire.  If I could select wich event I would like to cancel, it would be better but I can live with all events cancelled.
Thank you,
Simon-Pierre
Message 11 of 14
(2,851 Views)
edited
Message 12 of 14
(2,851 Views)
Accepted by topic author sppelletier
Thank you,
Simon-Pierre
If you want to prevent certain/all events from occuring after the first event you can disable the controls. This will prevent the event from occuring. Any controls not directly tied to the event structure do not need to be disabled, only the ones you that you have event cases for. If the control is disabled no event will be triggered. Other than maintaining some type of state information within the loop containing the event structure along with programmatic filtering of the event (simple case statement which prevent code within an event case from running) there is not way to simply clear the event queue.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 13 of 14
(2,844 Views)
Ok then, I will disable the button while I'm executing the event and release it afterward.
thank you all for your answers.
Simon-Pierre
Message 14 of 14
(2,837 Views)
