clear graphic and restart graphic
 oh, I am so so sorry, what i have done, it's my friend who wrote. please accept my apologize. and just he wrot in capitals, he did not mean that.
we are sorry.
Message 11 of 22
(2,392 Views)
coq rouge, if you forgive me, can you tell me there is only one kind of graphic can build history?
Message 12 of 22
(2,358 Views)
anyone can help me
now like this, it just can show 20s after that it stops, i don't know why?
and i want the time is 0 to 20, not like this.
thanks very much.
帖子被xiuming在 05-31-2009 01:36 PM
时编辑过了
Message 13 of 22
(2,355 Views)
You have a serious problem in your VI.  The boolean wire that terminates the inner while loop comes from outside that while loop.  If that wire is Tru, your inner while loop will run only one time.  If that boolean wire is False, then the inner while loop will run for ever and the only way to stop your program will be to hit the abort button.  Since the Stop button is read before the inner loop starts, there is no way for that value to be read again.  It is a basic principle about dataflow.
I would recommend you learn more about LabVIEW from here. How to Learn LV
Message 14 of 22
(2,344 Views)
Accepted by topic author xiuming
Si tu as LabVIEW français j'imagine que tu es français ?! J'ai repris ton VI vite fait : cf pièce jointe. Pour le graphe déroulant, tu as décoché la mise à l'échelle automatique pour l'axe des Y, je te conseille de recocher cette option. Pour l'axe des X, tu dois le gérer par programmation en utilisant les propriétés adéquates.
Message 15 of 22
(2,334 Views)
merci bp, j'ai réusi que chaque 20s il efface une fois, la graphe deroulant ne correspond pas parfait ement ce que je veux, c'est 'échelle X temps, je veux qu'il affiche comme
par example: il y a 20  points correspondent 20 seconds.
  je veux d'abord , t =1, affichage y1;
                             t=2, affichage y2, y1;
                            t=3, affichage y3,y2, y1;
                            t=20, rien affichage;
                             si  t= 21
                               t=1, afficage y21;
je ne sais pas si j'ai exprime bien ?
Message 16 of 22
(2,318 Views)
xiuming
Please use the scoop chart mode. And if you want 20 seconds data in chart you must set set the chart history length to sample rate *20 In your current software this is 11025 samples pr second. DO not make it any harder than it is 😉
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 17 of 22
(2,304 Views)
Smiley Very Happy  thank you coq rouge
I am so happy to get your reply! so we are cool now.
and I have managed to display the data of the 20s, but if i want to show X scale in real time not 20*11024, what should i do?
Smiley Wink
Message 18 of 22
(2,287 Views)
See the screenshot I have attached in a previous post. You must use "Xscale.Multiplier" property and wire the correct DeltaX (1 divided by frequency). You must also use "Xscale.Offset" property and update it every 20 seconds (by wiring a 0 value to it). That's already done in the screenshot : just have a look at it.
Message 19 of 22
(2,272 Views)
Message 20 of 22
(2,262 Views)
