clear indicators
I am working on a big VI wich can be restarted from the beginning using a loop. I want to clear al indicators when i am starting the program again (second loop). I can clear them all manually but this is a lot of work, is there a other way to do this?
Thnx,
Bart Bakels
Labview CLD , Engineer/Manager
Promedes and DSM
using LV 7.1, 8.0, 8.2, 8.5 and 2009 SP1
http://www.promedes.nl
(2,698 Views)
Hi Bart,
you could use the invoke methode 'Reinitialize All To Default' to reset all your front panel elements (not just the indicators).
-B2k
(2,695 Views)
thanks 😄
Promedes and DSM
(2,689 Views)
